3D printer recommendation?
We are a newly established company. I am looking for 3D printer to produce prothetics parts,considered as medical devices. Can the community advise on printers, and materials? We have to consider that the through put will be low at the beginning and will increase later. We might be at prototyping level to start with. Can we use smth like there printers https://43dprint.org/best-3d-printers-under-2000/?
Hey @Phil1!
Your post is rather vague.
Could you possibly provide more insight into how you’re looking to leverage Airtable in your workflow?\
It would also be really helpful if you could tell us a bit more about your current workflow and systems so we can more accurately provide some pointers on how you can go about building a solution for you and your team.
You will not get any useful advice unless you state:
Materials to be used.
Volumes expected.
Maximum size.
Budget.
and much more - this may help…
