Ability to drag and drop fields to customize record view
It would be very helpful to have the ability to customize the Record view to move fields around, create fields next to each other and create sections. Drag and Drop would be ideal.
Take a look at the new Interface Designer.
It isn’t the same as being able to customize the existing expanded view, but it has all of the features you mentioned. You can also create a button field that will open the current record in an interface.
Also, you may want to check out the 3rd-party app On2Air: Amplify:
Hey Brooke,
On2Air Amplify can do this and a whole lot more, as @ScottWorld mentioned.
Rearrange fields
RearrangeFields_DisplayHideFields_Amplify
Create record dashboards
CreateCustomRecordDashboards
Here’s a full list of all the features:
Airtable - On2Air Amplify Features :star:
