63745members
148077posts
Community Activity
Airtable Top Contributors | March 2024
Happy Spring, Airtable Community, and welcome to the March edition of our Top Contributors post! Each month, we love to shout-out the incredible individuals in our community who go above and beyond to help others excel in their Airtable journey. Our...
  • 0 Views
  • 0 kudos
Editing Comment Notification Email
Is it possible to edit the email notification that is sent out when you @ a specific user?For context;  as our purchase order moves through various stages, the access to those stages is dynamic.  When a user a elevated stage access comments at a user...
  • 7 Views
  • 0 kudos
Update records from google sheet
Is there anyway to generate an automation that updates field records within a table by matching values in a different column, similar to an Index/Match function, between AirTable and Google Sheets? Essentially, my team manages IRB protocols and we ne...
  • 13 Views
  • 0 kudos
Page Designer - Various Pages for different table values
I have a table that has a column, lets call it Food. I want to create datasheets for the drop down options I have set up for the food column and I am looking for a way to cater a page set up based off what drop down option is selected. For example: T...
  • 22 Views
  • 0 kudos
Workday function showing weekends
I am trying to have a due date automatically calculated, but don't want weekends or holidays included. I am using the WORKDAY function, but still getting weekends. Workback from is the date to begin working on each task and Workback is the number of ...
  • 21 Views
  • 0 kudos
Splitting Client Names into Two Rows
I am building a base for client follow up. When our clients are a couple, they are entered on the same row in our main table. I have the client name column as a look up field in our Client Birthday table, so it pulls the name from our main table. How...
  • 32 Views
  • 1 replies
  • 0 kudos
Syncing schema / table structure between bases
I have a schema, which I would like to implement for 3 similar businesses.  Is it possible to have the same base template, and have the schema synchronised between ALL 3 bases?  That is, if for example I add a new table, it is also added on the other...
  • 24 Views
  • 0 kudos
Published Form missing Helper Text
I have published a form and used the helper text as a description for some fields. When I preview the form within my account, it looks great. When I try to use incognito mode or a different account to view the form, the helper text is missing. Can so...
Screenshot 2024-04-25 at 9.55.43 AM.png Screenshot 2024-04-25 at 9.55.35 AM.png
  • 52 Views
  • 0 kudos
Automation to populate field from different table
Hello, I am looking to build automation.I have 2 tables: Task and Sub Task (both are linked). If a subtask is created under the task record, then the project selected on the task should be auto-populated in the subtask project field related to the sp...
  • 55 Views
  • 0 kudos
Announcements
Happy Spring, Airtable Community, and welcome to the March edition of our Top Contributors post!  Each month, we love to shout-out the incredible individuals in our community who go above and beyond ...
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
