Adding markers from different bases to same map
Topic Labels: Extensions
738 1
Shelley_Ostroff
HI!
I’m creating three forms for an event -individuals, groups and events - and I’d like them all to appear on the same map.
Can someone explain how to add markers from different bases to one map?
Thanks,
Yan
Bill_French
17 - Neptune
17 - Neptune
Two ways -
  1. Synch all the tables into a new base and then build your map there;
  2. Use the Airtable API to craft your map separate and apart from Airtable’s map using Mapbox or other tools.
Bill_French
17 - Neptune
17 - Neptune
Two ways -
