Adding Records in the Gantt-view per click-and-drag doesnt work
Topic Labels: Views
755 0
Peter_de_Leeuw
In the Help-Database, there is a description saying how to add records directly into the gantt-view by using click-and drag.
This doesnt work for me; after having clicked and dragged, the square dissappears as soon as I let loose.
Adding records by rightclick works well, but unfortunately doesnt add the group i click on, like it automatically happens in a grouped grid-view .
Anyone having the same experience, or even better, a solution for me?
(I have all rights to create records in the database and the view is my own.
I work in the Windows-App.)
Thanks, Peter
0 Replies 0
