Airtable Automation - Update Record
Topic Labels: Automations
2193 2
Matt_Kivlin
Is there a way via Automations-Update Record to set the Field value to a formula? I’m able to correctly set the trigger (tests successfully) and have set the Update Record Action to Record ID of the record(s) captured in the trigger.
I can set my field output to a specific value (i.e. string for example), but I’m not seeing a way I can set the field update value to anything leveraging a formula. Is this currently supported does anyone know?
Create a formula field with the formula that you want. Then update the actual field with the value of the formula field at the time of the automation.
Thanks for the help on this, that works great!
