Airtable / Database Build Out: Need Help ASAP
2225 4
Austin_Benton
Hi! I have a csv export for a 500 or so records that get generated each day. The report contains leads I generate for clients and calls we make for them. Currently it’s just a data dump but I’d like a savvy Airtable expert who can build a template with Blocks (pivot table / reports block) to make it insightful for me (how often are leads being called, for which clients, which of my callers are producing and which arent) and nice looking for my clients to view.
Help needed asap, please reach out if this is a match for your skillset. thx
4 Replies 4
Diane_Elkins1
Hi Austin,
I would love to learn more about your project. Let me know a convenient time for you to schedule a call.
Thank you,
Diane Elkins
diane@positiveworkspace.com
frank_johnson
HI Austin,
I am interested in your requirement and would be glad to assist you.
please reach me out through s.k.y.p.e cis.am3
Thanks
Frank
Frank@cisinlabs.com
Andrew_Johnson1
8 - Airtable Astronomer
Hi Austin,
Having worked on some similar projects in the past I would be happy to help you.
You can reach me on andrewjohnson56782@gmail.com
Best Wishes,
Andrew
Anonymous
Not applicable
I’d be happy to discuss some ideas with you via a free phone consultation. After that, I can provide a price and turn around time to help you get this going.
Schedule a call via this link:
You can also connect with me on linkedin - http://linkedin.com/in/eckline
Best,
Eric
