Airtable + JotForm - how to overcome linked fields limitation
Since Airtable does not have save-state feature and my form is long, I had to move to JotForm for my form builder
However upon integrating JotForm into Airtable and in the field mapping process - I found that it does not support passing of Airtable’s linked-fields data to be mapped into JotForm.
Does anyone know the solution to this problem?
This is exactly the problem we solved with our On2Air: Forms product that integrates Airtable and Jotform. Check it out here: https://on2air.com/on2air-forms
