Airtable -> JS -> Pagination = Problem to get work
Topic Labels: API
1689 0
AD_Ser
Hello there so here the situation
I’m creating a Laravel + Airtable Website
this is what I did :
  • so first I created my design & page
  • convert them to blade.php
  • I created a JS file to fetch data from my Airtable base with multiple field & tabs
  • parse those data to pages
here the code :slightly_smiling_face:
var type = "Regions"
var api_key = "?api_key=*************"
var perPage = "&pagesize=2000"
var maxRecords = "&maxRecords=2000"
var url = "https://api.airtable.com/v0/app*********/" + type + api_key + perPage + maxRecords + "'";
const app = document.getElementById('root')
const card = document.createElement('div');
card.setAttribute('class', 'rightcontainer w-container')
app.appendChild(card)
async function catchJson() {
    const response = await fetch(url);
    const data = await response.json();
    if (response.status >= 200 && response.status < 400) {
        data.records.forEach(records => {
            const records_length = document.getElementById('number')
            records_length.innerHTML = 'Liste de Regions<br> <h1> Il y a ' + data.records.length + ' regions </h1> <a href="" class="button-2 left-aligned w-button"><span class="text-span-2">Ouvrir la Map</span></a>'
            const property_card = document.createElement('a')
            property_card.setAttribute('class', 'property-card left w-inline-block w-clearfix')
            property_card.style.background = "-webkit-gradient(linear, left top, left bottom, color-stop(29%, hsla(0, 0%, 100%, 0)), color-stop(68%, rgba(0, 0, 0, 0.5))), url('" + records.fields.image_url + "');";
            property_card.style.background = "linear - gradient(180deg, hsla(0, 0 %, 100 %, 0) 29 %, rgba(0, 0, 0, 0.5) 68 %), url('" + records.fields.image_url + "');"
            const image_quantity_div = document.createElement('div')
            image_quantity_div.setAttribute('class', 'image-quantity-div')
            const price_text = document.createElement('h1')
            price_text.setAttribute('class', 'price-text')
            price_text.innerText = records.fields.Nom
            const div_lower_info = document.createElement('div')
            div_lower_info.setAttribute('class', 'div-lower-info w-clearfix')
            const info_text = document.createElement('div')
            info_text.setAttribute('class', 'info-text')
            info_text.innerText = 'Avec ' + records.fields.Count_Villes + ' villes et ' + records.fields.Count_Coupons + ' coupons affiché(s)'
            const view_button = document.createElement('div')
            view_button.setAttribute('class', 'view-button')
            view_button.textContent = 'Plus'
            root.appendChild(card);
            card.appendChild(property_card);
            property_card.appendChild(image_quantity_div);
            property_card.appendChild(price_text);
            div_lower_info.appendChild(info_text);
            div_lower_info.appendChild(view_button);
            property_card.appendChild(div_lower_info);
    } else {
        const errorMessage = document.createElement('marquee')
        errorMessage.textContent = `Gah, it's not working!`
        app.appendChild(errorMessage)
document.addEventListener('DOMContentLoaded', function () {
    catchJson()
this is the results: screenshot-web.pinkmarket.co-2021.11.15-02_23_38
Here now my problem :slightly_smiling_face:
I have more than 1000 records to fetch, but Airtable API by default can only give 100 records at a time cause Airtable use the API Offset Parameter
But how now can I do that to transform my JS and my page to add some pagination ! I’m a little confused and a little perplexed.
Sorry for long explanation and maybe more headaches :smiling_face_with_halo: !!!
And thanks for everything !
0 Replies 0
