Airtable to Power BI - converting multiple select columns
Topic Labels: ImportingExporting
903 1
Eric_Yang
Dear Airtable Community,
I’ve been using the following guidance on Power BI queries to import my Airtable data: Sending Airtable data to Microsoft Power BI & Power Query – Airtable Support
However, post-import, I’ve noticed that my multiple selection variables are just converting into “[List]”. Is there anything I can add to the query template code that would tell PowerBI to craft new columns to capture all of the multiple-select inputs, or at the very least pull the first selected input?
Thanks in advance!
aviad1aviad
Hello, did you manage to overcome the problem?
