Airtable window shrunk when dragged to another monitor
1043 2
Stephen_Dixon
When I drag an Airtable window to another monitor, the window creates a large buffer white space around Airtable limiting visable area. Also, this forum will not let me post an image to show you what I mean.
Airtable support has not been helpful. After 5 email exchanges, I keep getting the same response…
" Request [#14813] “Airtable window issue” was closed and merged into this request. Last comment in request [#14813]:
Airtable window malfunction when dragging the window to a second monitor.
When I try to click the links I get an error.
Define “Drag an Airtable window”: What exactly are you dragging? What are you using – the Airtable app or Airtable opened in a browser? What OS and (if applicable) browser?
It is the Airtable app in Windows 10, not Airtable opened in a browser. I am using a new laptop (Dell XPS-13, 3840x2400 resolution) and a new monitor (27" LG, 3840x2160 resolution). I used to be able to drag the window between laptop and monitor, but it recently started doing this.
