Syncing schema / table structure between bases
I have a schema, which I would like to implement for 3 similar businesses. Is it possible to have the same base template, and have the schema synchronised between ALL 3 bases? That is, if for example I add a new table, it is also added on the other...
- 16 Views
- 0 replies
- 0 kudos
