I am entering a bunch of field from left to right. I have several Columns that span from the left to right portion of my screen. Sometimes my eyes betray me and I start looking at the wrong row. I used to change my Excel spreadsheets to a style that altered the row color from white to another light color like blue or grey so that you can easily see the row you are on. I found it easier to follow the row across like this …
I don’t think there’s a way to do this in Airtable. You may want to submit it as a feature request in the Product Suggestions topic.
However, in the meantime, you’ll notice that if you click into a record, that entire row changes its color to a light grey, to distinguish which row you’re currently working on from the other rows.
@ScottWorld I changed the category for this post to move it to Product Suggestions, as the added request from @Marina_Michaels is pretty much guiding the discussion in that direction.
