Once a project is completed, what the best way to archive it so the information is available to reuse or reference later?
The best way to do this would be to use dedicated Views with Filters to see what you need to see and filter what you don’t need to see.
You’ll need a field to filter on. Two options work here:
- A Single-Select field called “Status” with options like “In Progress” and “Completed”
- A Checkbox field called “Completed” that can be checked when a Project is complete
Then, you’ll want at least 2 Views, one of which filters out “Completed” projects - those you can treat as “Archived”, as they don’t show in your main working view, but they are still there and searchable:
New Idea:
Make VIEWS of COMPLETED Projects and Tasks
MAKE A COMPLETE DUPLICATE OF BASE…rename it as ARCHIVE.
In the ARCHIVE DATABASE Filter and DELETE ALL OPEN PROJECTS and OPEN TASKS.
Then when you complete a Project in ACTIVE BASE. COPY IT to the ARCHIVE BASE and DELETE from ACTIVE BASE.
If you need to re-start an ACTIVE project, you can re-copy the COMPETE/ARCHIVE Project back to the ACTIVE Base.
This is a work around since there is NOT an ARCHIVE FUNCTION. If you only complete a few projects per month, this is not too much extra work and keeps the active BASE “clean”
