Are Stacked Bar Charts not possible in Interfaces?
1736 3
Ruchika_Abbi1
7 - App Architect
7 - App Architect
How do I configure Stacked Bar charts? I can’t seem to find any option in the Chart properties in the Interface.
Screenshot 2022-07-21 at 6.40.54 PM
3 Replies 3
Hidro01
They are only possible when you have some groups., then you can select grouping by:
triple
Is the field a single select? What do you mean by groups?
Thank you. Take care!
Hidro01
Yes like a single select field.
you can use these to create a stacked bar chart as in the picture.
