auto-number gives a new record the next higher number and that number is not changed if the sort order of the table changes. That’s how auto-number is supposed to work. It creates a unique identifier so to say for that created record.
You want to change the number every time the sort order of a table changes. This is only possible with a script in my opinion, but also not really necessary as you have the number already based on the “row number” on the left.
Why do you want to do that? I think that would make it clearer.
Have your API request the records from the specific view, not just from the table. Then the records will be in the view order and you will not need a separate field to determine the order.
So I have set of Records, I want to retrieve them in the order that I placed in the table, but API records response giving me in random order so, I’m using this field to sort them when I requesting the API using sorting method. That is the usecase, so that is why I’m using a separate field. Its working fine I have no issue.
But let say I have 100records all order sequentially in the table, now if I have to add lets say a new record in 44th place in the table, as Im use auto number that new record will be having OrderID as 101, so when I call the api I will receive that new record in 101th place instead of 44th place.
I don’t know. If the REST API works the way the scripting used to work, records are not grouped. When getting records via scripting, the records are sorted correctly compared to others in the same group, records in the same group are not necessarily together.
So it sounds like you’re able to sort records via API. Otherwise, this seems to be a good blog article explaining it: The right sort of API updates
When records are sorted, they are in the correct order I suppose. If you have 100 records and you want to add a 101st in 44th place, then I would splice() that record into the array at that place. Now you have 101 items in the array and it sounds like that you want to change the “order number” every time you do this. So given your sorting order, the order number is the index in the array.
You will then have to update all records accordingly. I’d create an updateRecordsArr first by mapping over your sorted records array ({id: …}, fields: {“field 1”: …, “field 2”: …}).
Keep in mind that you can update only 10 records at a time using the REST API, with a rate limit of 5 requests per second. If you have a lot of records, that will take a while. Plus, you can get only 100 records at a time to begin with, so if your table might have several hundred records, this whole process could take a really long time.
