Auto replicating tables in the same base
1204 1
Darryl_Holliday
Is there a way to automatically replicate rows in a table into another table in the same base? i.e. if i have one table set up, can I create a new one that is identical to the first and also automatically updates as new records are created in the original table.
Thu_Anh_Nguyen
I have the some query. Hopefully someone can give advice on this.
Thanks
