Hi! I’m trying to use automation to input a duration in a duration field from a text field but it doesn’t seem to work (i.e. after automation, 08:00 in text field appears as 0:08 in duration field). Is there anyway to make this work?
Duration fields store the value in seconds, so multiply the value by 60.
