Automation field collaborators
Topic Labels: Automations
2425 5
Jose_Guerrero
I can’t update the collaborators field when creating a new record, I want to add collaborators by default. how can i do that?
5 Replies 5
I’m able to update Collaborator fields. What are you putting in for the field value? It should work if you pass in the full name.
Tim_Sullivan
7 - App Architect
7 - App Architect
Are you asking how to have a certain field auto-populated with collaborators when creating a new record?
Jose_Guerrero
When new record is created, I want to add collaborators automatically (update the collaborator field).
In the automation configuration, I do not see any collaborate to choose, and if I type them manually, it does not let me activate the automation
Are you typing in the name of a collaborator exactly as it appears in their account, without any quotation marks?
yes, I added the collaboratos with a comma. It already worked, thank you very much for your help, I missed adding the record ID in the previous step.
