Automation for "done" checkbox
Topic Labels: Automations
785 1
Emily_Theys
I’m fairly new and trying to create an automation so that when I have completed a task, it goes to the bottom of the page, or a separate tab once it’s clicked as “done.” I’ve made a new column with a checkbox, but what’s the process for automating?
Thanks so much!
Sounds like you just want to filter or sort by the checkbox field, it doesn’t sound like you need an Automation at all.
