Automation - Run Script - allow to Set label/title for script
Topic Labels: Automations
1380 1
Maxim_KM
Hi guys, it’s a mess that cannot change or set the name for Run a script. If I have more than one module - it’s difficult to navigate among them.
Please consider this ability
18 - Pluto
18 - Pluto
You can add a description for the action. That will show up underneath the “Run a script” heading and make it easier to see what each script in your automation does.
18 - Pluto
18 - Pluto
