Automation Script for uncheck box in specific time using At scheduled time
let table = base.getTable(“Cuentas Ads”);
let view = table.getView(“check grupal”);
let query = await view.selectRecordsAsync({fields: })
let updates = query.records.map(r => {
return {id: r.id, fields: {“Check Grupal”: false}}
while (updates.length > 0) {
await table.updateRecordsAsync(updates.slice(0, 50))
updates = updates.slice(50)
