Automation script updating duration always results in 0:00 value
Topic Labels: Automations
1272 2
Greg_Jarmiolows
I am passing a duration type field a number value for update:
let [audioFile, duration] = await concatenateFiles(audioUrls);
console.log(duration); // this is showing a number with decimal
// make the update
    AudioURL: audioFile,
    Duration: duration,
    Status: {name: "Done"}
All 3 fields are updated but the duration is always zero after this update. Do I need to supply something other than a number to the duration data type?
Edit: I tried to use Math.round(duration) to no effect
18 - Pluto
18 - Pluto
Can you show a screen captures of the console.log(duration) output?
What are the setting for your duration field? Does it show hours, minutes, and second? Or does it show only hours and minutes?
Duration fields are usually sent in terms of seconds.
18 - Pluto
18 - Pluto
Duh Greg. The format was showing minutes but not seconds.
