Automation stuck
Topic Labels: Automations
951 1
Binthout_BV
I have an automation that’s being ‘stuck’ in a vicious circle:
  • I can’t press the ‘Update’ button on the bottom (well…I can, but nothing happens)
  • I can’t switch the automation off because it isn’t updated
  • I can’t delete the automation because it isn’t switched off
In the meantime the automation keeps generating error reports by email, which is annoying my boss ;-).
Can somebody shine a light on this? :slightly_smiling_face:
KrysFree
Experiencing the same issue with an automation that I setup.
Frustrating… can someone add this to a backlog for review?
We need to remove at least one of the blockers, at least allow us to delete an automation, even if it is on. If the automation is not working but still switched on we should at least be able to set it up over again, until the bug is fixed more thoroughly.
