Has anyone else run into this? I have several automations set up on my base, and a week or two ago some of the automations using the Run a script action started randomly failing with the error message An unknown error occurred.
When I look at the log, it just says ERROR: There was an unexpected error while executing your script.
I haven’t found any way to fix it aside from just re-triggering the automation on whatever records weren’t processed.
