Jul 24, 2018 01:50 AM
Im making a airtable system, for a friend of mine.
It deals with quite sensitive data…
Is there a way to make sure an editor can’t just duplicate a whole his base including all records into their own workspace, but still be able to edit records?
Oct 31, 2018 07:21 AM
Did you ever get a response to this issue? We’re facing the same dilemma
Oct 31, 2018 07:38 AM
Unfortunately not.
We’re sofar working under the pretence that no-one would ever think of it being an option… And sofar it haven’t been a problem.
But guess it’s like an insurance; you never need it until it’s too late…
Feb 04, 2019 08:21 AM
That’s crazy. It’s a huge security issue. That way the sensitive info of clients can be easily duplicated multiple times by multiple (nested) invites. I cannot understand why Airtable does nothing about it. No need to be genius to steal the whole CRM
Feb 04, 2019 08:59 AM
your question is sub-feature of a major long running feature request Advanced User Permissions
Feb 06, 2019 06:21 AM
thank you Michael. Do you know if it is possible to see whether the base has been copied? Some kind of history
Feb 06, 2019 06:50 AM
I’m pretty sure no, but I’d suggest you try to copy a base with multiple users on it and see if anyone gets a notification that they are part of a ‘new base’
Mar 07, 2019 02:55 PM
It is a big problem for us, I can’t understand why we don’t have a way to block “duplicate base” feature.
Jan 19, 2021 06:33 PM
Is this still an issues in 2021?
If so, this needs to be addressed. This is kind of a deal breaker.
Jan 20, 2021 03:08 AM
I’m actually not sure, I’ve just continued on the assumption that no-one would do such a thing… :grimacing:
Jul 03, 2021 10:48 AM
I agree, and in a GDPR context, it’s uncompliant :upside_down_face:
Jul 03, 2021 11:26 AM
Yep, it’s one of the major security holes in Airtable (yes, there are more of them).
You could use a portal tool like MiniExtensions.com to create a more secure user frontend for Airtable, but then you lose all of the interface benefits & most of the features of Airtable.
I would recommend that people keep emailing support@airtable.com about this issue. Although it’s been 6 years and they haven’t cared enough to address this issue, so it’ll likely never happen.
