Best Way to Link up Contacts & Companies
1249 1
Bryan_Nowlan
Hello, currently I have a database on Airtable that lists a contacts name, email, company, email, phone, etc. I’m looking to create a new tab for just their companies, that properly links back to the contacts. For example, it would be pulling all of the companies onto a new tab and then ideally being able to link back to any contacts associated with that company.
What would be the best way to set something like that up? Thank you in advance for the assistance!
Hi @Bryan_Nowlan - you’re almost there based on the description you provided. Just create a “companies” table, then change the companies field on the contacts table to be a linked field (linking to the companies table). This will create the records of each company in the companies table, linked to the appropriate contacts.
