Hi there,
I’m writing a script to compare two tables (views
actually) and mark the records that match.
I wrote a script that compares View 1 to View 2. And then needed a way to compare the other way around, View 2 to View 1. The problem is I got a big chunk of duplicated code and surely there’s a better and more elegant way to accomplish this. Right?
Here’s the setup section of my script, nothing fancy:
//get table
let table = base.getTable("Table 1");
//get records in the App View
let AppView = table.getView("App");
let AppRecords = await AppView.selectRecordsAsync({fields: ["DateApp", "Payee", "Amount"]});
let AppExpenses = AppRecords.records
//get records in the Bank View
let BankView = table.getView("Bank");
let BankRecords = await BankView.selectRecordsAsync({fields: ["DateTransaction", "DateProcessed", "Payee", "Amount"]});
let BankExpenses = BankRecords.records
Here’s where I compare compare View 1 (App) to View 2 (Bank). And update the records:
// Find matches on App
let AppMatches = AppExpenses.filter((record)=> {
return BankExpenses.find((potentialMatch)=> {
// compare record to potential duplicate
return (record.getCellValue("Payee") === potentialMatch.getCellValue("Payee") &&
record.getCellValue("Amount") === potentialMatch.getCellValue("Amount") &&
(record.getCellValue("DateApp") === potentialMatch.getCellValue("BelegdatumConverted") ||
record.getCellValue("DateApp") === potentialMatch.getCellValue("WertstellungConverted")))
let updatesApp = AppMatches.map(record => {
return {
fields: {
"Match": true
while (updatesApp.length > 0) {
await table.updateRecordsAsync(updatesApp.slice(0, 50));
updatesApp = updatesApp.slice(50);
My issue is that I need to perform the same comparison and update the other way around. So I have a big chunk of duplicated code that goes like this:
// Find matches on Bank
let BankMatches = BankExpenses.filter((record)=> {
return AppExpenses.find((potentialMatch)=> {
(record.getCellValue("BelegdatumConverted") === potentialMatch.getCellValue("DateApp") ||
record.getCellValue("WertstellungConverted") === potentialMatch.getCellValue("DateApp")))
let updatesBank = BankMatches.map(record => {
return {
fields: {
"Match": true
while (updatesBank.length > 0) {
await table.updateRecordsAsync(updatesBank.slice(0, 50));
updatesBank = updatesBank.slice(50);
I’m wondering if there’s a more efficient way to perform this two-way comparison?
