Jul 25, 2018 08:16 AM
I’m hoping someone is able to assist with this. We are trying to build a Bill of Materials for our products. I have a Products and Parts tab. The Products tab pulls the list of parts from the Parts tab using ‘Link to Parts’ and totals the costs using ‘Roll-up’ to determine our cost per product. However, the issue I run into is when some of the products have multiple of the same part. I can’t find a way to make this work as the roll-up formula I am using only pulls one of each of the listed parts, while I need it to pull multiples of specific parts for an accurate total.
i.e.
What it does now: 1x screw, 1x case, 1x cable
What I need: 6x screws, 1x case, 2x cable
Thank you.
Jul 25, 2018 10:19 AM
Can’t you add a ‘quantity’ field to the Products table and then have a formula to calculate the cost?
I think it is not posible to do what you ask for because there is no criteria to know how many parts you want to pull from the Parts table.
Jul 26, 2018 07:21 AM
I think you need a join table to contain the line items
like in an Invoice.
Now you can have the Rollup you want, but to the joint table, to the Total Cost field.
