Blocks - Chart Settings - Number of records
Topic Labels: Extensions
1498 3
Sam_Herbert
Hello Airtable Friends,
Does anyone know how to have the actual ‘number of records’ amount show in the middle of the Donut chart block?
I’ve attached a screen capture to illustrate where it states ‘Number of records’ but doesn’t show the total sum in the middle of the chart?
Many thanks in advance.
Cheers,
Sam
AT%20Block%20-%20chart%20settings
3 Replies 3
Susan_Mulraine
Wondering if anyone has a response to this? I am trying to figure out the same thing, for all charts/graphs - donut, line, etc…
Also wondering, this is quite important if you want to show quick higlights and need to copy paste the charts.
Kevin_DiBenedet
This question also applies to an interface designer dashboard we are trying to build. Can we show the totals of records/sums in charts without having to roll over each block?
