Blocks sdk catching save to ignore errors prevents block from working
563 0
Ronen_Babayoff
7 - App Architect
7 - App Architect
Hey,
The “ResizeObserver loop limit exceeded” is a completely safe to ignore error. See here.
It used to be that the blocks sdk only added a global window on error event listener in development mode so my blocks worked after releasing them. Now it seems to add the event listener in release mode too and displays the “contact developer” message.
Can you guys please check for that specific error in your error handler and ignore it?
Thanks,
Ronen
0 Replies 0
