Building KPI Dashboards with AirTable Data
2087 1
Victoria_Hirst
Bear with as I’m new to this product!
Does anyone have a recommendation for building dashboards with AirTable Data? I’d love something that could pull data from multiple sources, but has a strong ability to integrate with airtable.
Someone suggested to just copy and paste data into google sheets and build something in google data studio, but I want something that has a live connection and more robust integration features.
Thanks in advance!
Hi Victoria and welcome to the community!
Just use the integrated Airtable automation to maintain a synched Google table (or tables); no need to copy/paste in 2021.
