Calculated Fields not Returning 0 Values
Topic Labels: API
1920 1
Larry_Price
So, here’s another in my long line of small issued in the API. I have simple formula fields in my table that add other columns together. It’s literally field a = field x + field y + field z. When I return field a, the api doesn’t return “0” properly. Instead, I get the most recent non-zero value in the field.
It should look like: It Looks Like:
0 0
0 0
5 5
0 5
1 1
4 4
0 4
0 4
0 4
I’m using the API to generate simple reporting in Google Sheets, so I have apps script turning the api json object into an array of strings. I’ve verified that there isn’t any weird behavior here with 0 values in my implementation of the apps script. The api only does this on calculated fields.
My only idea so far is that the api is treating the 0 value in the calculated field as empty, but I’m not sure that would cause the behavior or what to do if that is the case. Thanks for any ideas.
Larry_Price
Update: It isn’t just calculated fields. Any field that returns a numeric value through the api won’t return blank or zero values. Instead, as notated above, the api will return the most recent non-zero value in the field . My work around for the moment is setting all zero values to some variation of 0.00001 as well as setting field defaults to the same.
