Calculating growth between numbers in same field
2403 4
Brett_Snelgrove
Hi there,
So I have a Table were I am tracking Costs in one field and in another field I have Financial Years.
Financial Year
19/20
Costs
$100
Financial Year
20/21
Costs
$200
What I would like to be able to do create another field where I calculate the growth from 19/20 to 20/21:
Cost Growth
100%
I’m really not sure how to go about this. Does anyone have any suggestions?
Thanks in advance.
4 Replies 4
nnnnneil
8 - Airtable Astronomer
Comparing values between records is tricky because you’re dealing with a database, not a spreadsheet, so the records have no intrinsic relationship. This can be done with some clever setup, though, which @W_Vann_Hall outlines here:
Thanks for the recommendation Neil :slightly_smiling_face:
Thanks Justin. That’s a three cup of tea read there. I’ll check it out.
:thumbs_up: :tea:
