Calculating total time using DATETIME_DIFF
I’m trying to set up a chart block to show total time spent on each project. My task entry table is set up with a record for each task with time start and time end fields. A third field named ‘Total’ contains the formula DATETIME_DIFF({End}, {Start}) with the format set to ‘duration’ to calculate the hours and minutes for each task. This works perfectly to populate the field in each record.
However, when I try to use that Total field as the Y-axis in the chart block, I get an error that the field is not numeric.
I have created a fourth field with a similar formula as ‘Total’ but with a unit specifier, and the format set to ‘decimal’. This works for my chart, but it’s showing whole hours with .00 behind the decimal:
DATETIME_DIFF({End}, {Start}, 'h')
format: decimal
precision: 1.00
How can I set this formula up so that it shows accurate times instead of rounding down to the full hour?
This topic was automatically closed 91 days after the last reply. New replies are no longer allowed.
