Can I create a report from a project management base
671 0
Christina_Davis
I want to use a project management base and then create reports for the executive team to show our progress.
  1. Can I create a report?
  2. Can I customize it to an in house standard template or a totally custom report with graphics without leaving Airtable?
    Thank you in advance for your comments and advise!
0 Replies 0
