So I have a table with a field Client that references a record from another table. Client column as such can contain a value such as ['rec1234abc']. Now I want to do a filter to return all records that reference a specific record. I tried this (using the Python client):
When referencing the data from a link field using the API, what you get back might be an array of record IDs. However, that’s not what comes back when referencing a link field in an Airtable formula, and the last part of that statement is key: you need to design your formula based on how the actual formula would operate within Airtable, not based on how you get data back from the API.
A common misconception is that a formula referencing a link field will return an array of values, but that’s not the case. What Airtable returns from a link field is simply a string containing the text from the primary field of all linked records, separated by commas.
To get the record ID of the linked record, you’ll need to first make a {Record ID} field in your [Clients] table (guessing the name based on the {Client} link field), roll that up in the table where the {Client} link field lives—I’ll call this rollup field {Client Record ID}, and suggest using ARRAYJOIN(values, "") as the aggregation formula so that you get a string—and then compare against that in your API call:
my_table.get_all(formula="{Client Record ID}='rec1234abc'")
First off, the field type is a link field, not a reference field. You’re creating a link between records across specific tables.
That aside, I’m not sure how the Python client operates (it’s not an official Airtable offering as far as I know), so I can’t offer much help with the specifics of the implementation. For example, what data types does the search method expect and return? Are you sure that searching a link field returns the record IDs of the linked records? It’s possible that it’s returning the primary field text (similar to a formula), so searching that text for a record ID won’t work.
That’s because it’s used in the aggregation formula of the rollup field that I described. I rewrote the formula in the query to look at the output of that rollup field, which is going to be the string created by the aggregation formula.
