Can I send and receive SMS using airtable?
1221 1
Shwetha_Shyam
Hello! Is it possible to send and receive texts on an airtable base using Twilio API? Most of the documentation here are focused around sending SMS, but not receiving them.
Hey there!
I think you’d need another service to do this. I’d recommend looking into Twilio + Zapier. Zapier allows you to trigger based on “Watch messages (SMS or MMS)”
You can then likely use the message into your Airtable base.
Good luck!
