Can shareable view links include blocks?
Topic Labels: Extensions
1128 4
paolability
I started using Airtable a few years ago to create a set of local resource directories re: COVID-19
I have public views which I share. I’ve now got free Pro access for a year. I created a block that embeds a table’s form link.
The share link expands to a URL with the query string blocks=hide
So, the block doesn’t showing up in my public view.
Removing the query string or changing ‘hide’ to ‘show’ doesn’t work. ‘Show’ displays the blocks panel with a spinning wheel and an error dialog in my table view: An error has occurred - Invalid permissions.
What should I do to make the form visible on the same web page as the table view?
Thanks,
Paola
4 Replies 4
William_Donovan
Has anyone reached out to answer this one?
No. However, I belatedly remembered that one could embed views and forms in a web page and so I used that to get a form next to a table.
Do you share the web with us to review your work on covid19?
