Can’t create an Interface using an iPad
907 1
Sam_Salerno
I’m using an iPad Pro, 11-inch, and having difficulty creating an Interface. I can configure it through the first few screens, but when it prompts me to add fields and forms, the screen continually jumps up and down with the “Open in the AirTable App” notification bar appearing and disappearing off the screen. Anyone else experiencing this or know a workaround (other than using a different computer)?
gaston
Hi @Sam_Salerno could you figure this out?
Founder @Boltflow
