Can't figure out an issue when using FilterbyFormula
Topic Labels: API
1668 1
Guy_Galonska
I’m using this code:
item_call = at.get(‘Master reference’, input_item)
Assembly_name = item_call[‘fields’][‘Assembly name’]
Assembly_bom = at.get(‘BOM’, filter_by_formula="{Part of assembly} = %s" % Assembly_name)
print json.dumps(Assembly_bom, indent=4, sort_keys=True)
I’m getting a 422 error, but can’t really figure out whats going on. Also, the same code seemed to work a few hours ago.
the 422 error url is:
https://api.airtable.com/v0/xxx/BOM?filterByFormula={Part of assembly} = ASB00004_Assembly
It’s important to say that {Part of assembly} is a linked field.
Thanks for any helpers!
Guy
Guy_Galonska
Nevermind. Solved!
Should look like this:
Assembly_bom = at.get(‘BOM’, filter_by_formula=’{Part of assembly} ="%s"’ % Assembly_name)
