Cart add with Store
Topic Labels: API
992 1
John_Brandi
     I’m looking for an app to build an Airtable Web App/Website, where the user can order directly from the application, with an add to cart button and thus a global cart payment.
I’m currently using Soft and I’m new to it.
There is the ability to add a payment button but the user has to pay for each product separately.
Maybe I should create an Automattic table for the orders so that I can calculate the global amount, instead of ordering each product, and thus create a payment button for the global amount.
Is there a simpler way to do that? I’m stuck
Hi @John_Brandi ,
Welcome to Airtable Community!
What you need is a Line Items table and an Orders table yes.
This might help
