Changing the Field Order in Interface expanded view
A couple of the most convenient things I found in Airtable are the little previews when adding a linked record and then the expanded views that are available with a click.
I wanted to make sure those previews were displaying the most helpful information and that the expanded view was ordered in a way that made sense, despite the varying field order amongst the different views. I realized the following:
Expanded View of a Linked Record accessed from a Table
The order and visibility will match that of the first view of that table. With hidden fields moved to the bottom.
Preview of a Linked Record
The fields previewed will match the first fields within the first view of the table regardless of visibility
I’ve been calling this first view of a table, an “Index View” because in some cases, they serve no purpose to me other than establishing field orders.
My question is, do the expanded view within Interfaces follow any similar protocol?
Expanded View of a Linked Record accessed from an Interface Elements
First, the fields set to visible will appear.
Then, some the fields used within the properties of the records will appear. (Groups, Data, Filters).
But there doesn’t seem to be any rhyme or reason beyond that. When changing the order in field visibility property it warns that “reordering hidden fields will not be maintained after closing”. So where is it getting the order from? Any insights?
Hey Mitchell! Great question. Both in-base and in Interface Designer, expanded linked records display fields in the same order as the top-most view. You can make any view the top-most view by dragging it to the top in the lefthand views panel.
I’m not 100% understanding the part about changing the order in the field visibility property but wanted to chime in with the above anyway. Hope this helps!
So we were using this method and it seemed to have changed a few days ago and now we cant filter it at all. I wonder if it is a bug or an update. Hoping someone has insight into this
Hi @Lauren_Robertello ! I’m understanding from your reply that the top-most view dictates field visibility and order when expanding linked records. Is there any way to change field visibility and order depending on which table I’m viewing the expanded linked record from?
For example I have tables A, B, and C. A and B both link to records on C. When I’m in table A and expand a linked record to C, I need to see fields 1, 2, and 3. But when I’m in table B and expand a linked record to C, I need to see fields 4, 5, and 6. If that’s not currently possible, it’d be an extremely useful feature. Thanks!
