Chart's initial drill down only displaying X & Y axis fields
Topic Labels: Extensions
490 0
Shawntel_Cote
It appears that the Charts are only showing the Primary field, X axis & Y axis field when you click on a section to drill down on the graph however it used to show the Primary field as well as the first few fields of the associated View.
So in this example it’s showing only the SO# (primary field); the PM & Status Field. However I would have seen SO#, Project Name and Site fields.
I can’t tell if I changed something or not, has anyone experienced this?
View’s Field Order:
0 Replies 0
