Column Width on my phone -Android
740 0
Dan_Long
First time user. Pretty happy so far with a simple inventory table for our little business. Unfortunately, working in the warehouse (greenhouses, actually) the app won’t show the full product name, even when I tip my phone sideways. I changed the column from Single Line Text to Long Text and it went from 5 characters to 13. I also changed the other fields to try to make them shorter (from single line to number and single line to check box).
Any thoughts? On my Grower’s iPhone it shows full text when she tilts the phone sideways. Mine doesn’t change. If this is simply a limitation of the App, how do I go about requesting a fix? I don’t want to carry a laptop around in the greenhouse.
0 Replies 0
