Can someone help me find % completed? So in my Airtable, there are various tasks and subtasks. For example, Legal will 5 tasks and the statuses are complete and not started. What I am trying to find out is if 3 of those 5 are complete then how can it display 3/5 in % terms in Legal. Same for Operations under Operations category. And lastly, I want to add total project completion percentage based on LEGAL and OPERATIONS.
I am trying to do this too. It should be a simple divide (/) formula. in your case it should be {complete}/{tasks}. As per the examole in the help see ‘Basic calculations > Divide’
I am trying to get % of female and male in a group by taking {no of F}/{Total} and it is not working the answer is 0 in every case. My total is a formula of the other 2 columns added together, i don’t know if this makes a difference.
I finally got this worked out. The formula is a divide one as I described, BUT, to get the % showing correctly, click on the ‘Format’ tab and select %Percentage form the drop down options.
Would be good if that final step was in the instructions somewhere.
