Connect airtable to Mailchimp, Wix, ActiveCampaign and other marketing tools
Topic Labels: Integrations
1303 0
Andrus_Purde
We at Outfunnel have added an Airtable integration, that makes it super easy to connect Airtable to email marketing tools like Mailchimp or ActiveCampaign, or web forms like Wix Forms, Elementor, Contact Form 7 and Facebook Lead Forms. For example, you can sync new web leads into Airtable with Outfunnel, and then sync a table or a particular view of a table to a Mailchimp audience, so that the next time you send out a newsletter, you can skip the export csv-import csv bit.
We’ll continuously be adding marketing tools you can create connections with (at least 2-3 more coming before the end of the year).
How is this better or different than tools like Zapier, you may ask. Generic app integration tools are great for creating simple connections between Airtable and other apps. But deeper marketing use cases can get complex and pricey very quickly. We’re a team of marketing and sales pros and we’ve poured our hearts into making our marketing integrations super useful and easy. (Hope this wasn’t too promotional.)
Finally, is there a marketing tool you’d like to integrate your Airtable with? Would love to get ideas for our roadmap.
0 Replies 0
