Connecting excel to trello (converting excel to airtable to connect to trello)
Topic Labels: Integrations
808 2
Alexander_van_S
Hi all,
I’m working as a lean consultant. Helping teams to reach their business goals.
I currently experiment with a system that uses excel and trello but they are not connected.
I believe airtable could solve this. The solution would be a great product that could help 1000’s of teams all around the world.
So I have a vision. I have a mvp. I just need help to get it working in a lo code to like airtable.
Could anyone help me with further resources? Ideally I would speak with an air table expert and show what I have already and explore if air table would be able to connect my two parts.
Thanks so much for your time,
Alexander
Alexander_van_S
Thank you! I will look into that. Also I found someone to help me on upwork. So I’m good for now.
Thanks again!
You can use Integromat to connect Airtable, Excel, and Trello to each other:
Alexander_van_S
Thanks again!
