Connection to a base from a 3rd party service through a block
556 0
Tom_Beckenham
Is there a way to maintain a connection to stream data from a base through a block? The reason I’m asking is that there’s a lot more information I can get about the base through the Block API than through the standard Airtable API.
0 Replies 0
