Content Security Policy directive blocks cdn.jsdelivr.net for review
1042 0
AdamSyd
My extension uses a react component (monaco editor) that downloads a .js from cdn . jsdelivr . net when it is rendered.
The extension was approved for Airtable marketplace in July (4 months ago) and it worked fine.
But now users are getting error when extension tries to display the editor and the browser console shows:
“Refused to load the script [link to .js on jsdeliver cdn removed] because it violates the following Content Security Policy directive” etc…
Extension communicates with my server with no problems, so the “Allow network access” for the extension is enabled.
Do I need to change the extension to no longer use that react component and resubmit to Airtable - which will probably take weeks - or is there another way?
Extension is: InfoPixo Live Charts
0 Replies 0
